2024-12-11 3:31 AM - edited 2024-12-11 4:36 AM
I use a STM32H5 with STM32_Safety_STL v4.0.0 library. Development tool IAR 9.60.3
Using the project NUCLEO-H563ZI without TrustZone in X-CUBE-CLASSB-H5 and compiling it, I have the following linker error:
SOLVED enabling option on 32bit tab: "DSP extension"
2024-12-11 8:16 AM
Hello @FPasq.1 ,
If I get you correctly you managed to solve the issue by enabling the DSP extension. if it is the case or you have more details, we can close the thread by marking a reply as solution for better visibility to other uses.
2024-12-11 8:16 AM
Hello @FPasq.1 ,
