I need your help about my project using STM32 F4 in cube IDE
Psaba.1
I want to implement a simple code on STM32 F4 which toggles an LED after receiving each UDP packet with "0x11 in payload" . Pleased give me a sample code in order to solve my problem. Thank you all.
> simple code
UDP on the STM32F4 is not simple. Perhaps review some examples. Expect it to take a while.
Pavel A.
Try to start from this example: STM32CubeF4/Projects/STM32469I_EVAL/Applications/LwIP/LwIP_UDP_Echo_Client at master · STMicroelectronics/STM32CubeF4 · GitHub
Port it to your hardware (board, ethernet PHY).
-- pa
