How to open files on Host PC with fopen on STM32L5
Domy_ST
Title edited to clarify that this is about accessing a file located on a Host PC
hello ST Community,
I'm trying to open a binary file with the fopen function for a STM32L5 microcontroller, but it always gives me a null value. The code is like this:
char filepath[256];
sprintf(filepath,"%s","C:\\fileBIN.bin");
FILE *file;
file = fopen(filepath,"rb");
if(file == NULL)
   printf("Error occurred opening file. \r\n");
else
   printf("File opened successfully. \r\n");
It always gives me a null value but the path exists and is correct. What's wrong?
Thanks for supports
23 REPLIES 23
@KnarfB wrote:
downside is, that this requires a driver on the host and is said to be slow.
Indeed.
@Domy_ST it also relies upon the debug interface - so you might just as well use that directly to do the programming!
Andrew Neil
@Domy_ST  I think your question about getting the bin file into a bootloader is now solved, so please mark the solution on whichever post you feel provided the best answer.
New question about issues with Semihosting split to a separate thread: Semihosting error: "Protocol error with Rcmd".
hi @Andrew Neil
I haven't solved it yet. Before proceeding with YMODEM, I was about to try the semi-hosting solution, but there's a problem with rcmd. As soon as I fix it, I'll mark it as solved.
The original question of "How to open a file on a PC from an STM32" has been answered (and turned out to be the wrong question anyhow).
"How to do YMODEM" and "How to do Semihosting", etc,  are separate follow-on questions.
