How to disable USB port through software
soobia
Posted on June 25, 2014 at 12:46
Sir,
I have successfully initialized USB port on Hi mini STM32F1V board now I would like to design a software routine to disable the initialized USB port plz help me out how to implement this.
#stm32f1-usb-port-programming
joe
Posted on June 26, 2014 at 11:00 I haven't done this but this is how I would approach it. The initialization is done by calling the function,MX_USB_HOST_Init(). This function calls
USBH_Init(&hUsbHostFS, USBH_UserProcess, HOST_FS);
The is a matching USB_DeInit function:
USBH_DeInit(USBH_HandleTypeDef *phost)
to which you would passhUsbHostFS. Then you can re-assign your USB GPIO's as required. Worth a try.
