How program STM32H7 via bootloader ? How read *.elf file to write into memory via FD CAN bootloader ?
NAmir.1
FBL
Hello @NAmir.1​,
You need to make a *.bin file that can be programmed using the bootloader.
You may refer to FDCAN protocol used in the STM32 bootloader - Application note
Hope this helps!
Best regards,
FBL
Typically you wouldn't push .ELF data over the wire, there's usually far too much noise in the file, and with CAN packets, you probably don't want to be sending that.
The .ELF format is very well documented, if you want to use that PC side, to process and extract the binary portions of it.
