Could TCPP01-M12 be used without the N-MOSFET?
‎2020-11-03 11:30 AM
We have a wide-input power management ic with buck-boost converter. 28V VBUS is not a problem. So is it possible to eliminate the N-MOSFET (at least in Sink mode)? If it is OK, what is your recommendation for connections of IN_GD, Gate, and Source pin?
USB-PD
‎2021-01-26 2:24 AM
To disable Vbus OVP (when DC/DC on Vbus is 25V compliant), you need to:
- Remove MOSFET on Vbus
- NC : SOURCE (4), GATE (5)
- IN_GD (8) : connected to 100nF
- VBUS_CTRL (6) : connected to GND
See X-NUCLEO-USBPDM1 modification.
‎2021-01-26 2:24 AM
