capacitance measurement example code
ADSB
Hello community,
is there example codes reflecting the application note (AN4112) for the capacitance measurement?
Thank you.
Imen.D
You can refer to the COMP example in the related STSW-STM32048 package:
STM32F0xx_StdPeriph_Lib_V1.5.0\Projects\STM32F0xx_StdPeriph_Examples\COMP
Best Regards,
Imen
Imen
ADSB
Thank you for your help Imen.
However, this is not what I am looking for. I want to see the possibility to use OC and IC of the same timer at the same time using HAL.
