AWS IoT with Nucleo-F767ZI?
MBlanco
So this is a related question to connecting through ethernet. I'm having trouble using my ethernet connection for AwS IoT. Are there any resources to do this? Most of what I found involved using wifi instead.
grd
An Ethernet-enabled board (NUCLEO-H755ZI) is supported through LwIP in the X-CUBE-AWS Cube Expansion Package v2.1.
It is a different MCU family, but since the Ethernet peripheral is basically the same, some code reuse should be possible.
grd
