2024-01-26 11:21 AM
I've seen other posts provide links to examples for "USB host application based on the Audio OUT class". Are there any for audio in?
2024-01-26 11:37 AM
Hello @EC.3
I suggest you to take a look at the X-CUBE-USB-AUDIO And try to adapt it to your MCU and project.
Best Regards.
STTwo-32
2024-01-26 3:08 PM
Hi @STTwo-32 ,
I've been looking at that too, although the examples it contains are for USB Device rather than Host. I'm going to see if I can mix, match and adapt with what I've come across so far, but I'll keep this ticket open a bit longer just to see if anyone happens to know of a more closely aligned example.
