STM32F746 Discovery pcb project
Den In
Posted on April 16, 2018 at 16:47
I need the pcb project for STM32F746 Discovery. I have the schematics, BOM, gerbers but the pcb project. Can I find it somewhere?
Thanks,
Denin
#pcb-project #stm32f746-discovery
6 REPLIES 6
Posted on April 16, 2018 at 17:04
You should discuss with your local ST representative or FAE if the materials are available and under what conditions.
Posted on April 16, 2018 at 17:15
Look file en.stm32f746g-disco_sch.zip at st.com
Posted on April 16, 2018 at 18:43
http://www.st.com/content/ccc/resource/technical/layouts_and_diagrams/schematic_pack/84/a3/95/2d/1b/90/47/33/stm32f746g-disco_sch.zip/files/stm32f746g-disco_sch.zip/jcr:content/translations/en.stm32f746g-disco_sch.zip
Haven't checked what exactly is covered in the CADSTAR files, and I'd likely assume you're using something else.
Den In
Posted on April 17, 2018 at 08:05
I have already checked the folder given at the link. The pcb file given there cannot be opened by Altium, or I could not have managed to. Is there a way of doing so?
Posted on April 17, 2018 at 12:33
If the format is not directly loadable then you will need to Import or Translate, or get a CADSTAR viewer.
Posted on April 20, 2018 at 14:00
Thank you very much. It's Altium's bad. Has been solved.
