STM32 strange flashing process
‎2017-05-19 8:25 AM
Hi!
When I flash a .hex or .bin file with a ST-LINK V2 device on my STM32F4 microcontroller (with ST-LINK utility), the program only works if both the ST-LINK V2 and my MCU board stay connected to the computer (through a USB cable). Whenever I unplug one of them the program just flashed on the board does not run anymore.
Does anyone have any idea of what is happening ?
Thanks for your help!
#st-link #flash-stm32 #st-link-utilitySolved! Go to Solution.
‎2017-05-22 4:46 AM
Thank you both of you but I managed to solve the problem.
It was actually due to the ST-Link device that was still plug to the MCU board and keeping it from running the program (even though it wasn't plug to the computer and not powered on...)
‎2017-05-19 8:45 AM
Hi
baures.tim
,- where your code is located? may be the flashed .bin and .hex are located in RAM!
- Pl
ease refer tothis application note to verifyyour hardware implementation:
-Nesrine-
‎2017-05-19 11:07 AM
Does your design pull BOOT0 Low?
Do you initialize all the clocks and pins your application needs? Debugger gets chip in a viable state for it's own needs.
‎2017-05-22 4:46 AM
