2025-08-04 4:40 AM - edited 2025-08-04 6:34 AM
Hi, I tried to connect my board to my computer trought USB but I can't recognize the board, it doesn't appear, I can't use the Programmer either. I downloaded different drivers, I used different cables but it doesn't work. What can I do? The BLE connection worked, I could get some data from a SD Card, but I want to use in a continuous measure.
2025-08-14 8:57 AM
2025-08-14 7:28 AM
What board ?
Please, give more info please, if you want to increase your chances to get an answer.
This can be pictures of your setup, schematic, screenshots, driver version, etc...
2025-08-14 8:57 AM
