OpenOCD with ST-Link/V2 onboard stm32f4discovery board
halherta2
Posted on March 13, 2012 at 21:03
 I looked at the openocd 0.6.0 scripts and found those for  stlink v/2 interface and stm32f4 discovery.  Does anyone know how would I setup openocd to make it communicate with the stm32f4discovery board via the onboard stlink v/2?
I have not found any instructions for this particular setup online. I also noticed that the official openOCD 0.5.0 release does not have these script files in them...only the 0.6.0 version
Thanks,
halherta
#stlink-openocd
sjo2
Posted on March 16, 2012 at 12:18
The stlink support in OpenOCD is relatively new, however it is working well.
To start using you have two options
1. Find a prebuilt version
2. build from source.
Personally i would opt for 2, the main reason being is that quite a bit of work is happening for stlink support so it may help to be using the latest and greatest.
http://www.freddiechopin.info/en/download/category/10-openocd-dev
is a good location for prebuilt windoze versions - i have not tested these however.
Once you get the binary then it is just a matter of selecting the correct scripts, eg. for a STM32F4DISCOVERY you would use:
openocd -f board/stm32f4discovery.cfg
Also have a read through the online
http://openocd.sourceforge.net/documentation/online-docs/
Cheers
Spen
halherta2
Posted on March 16, 2012 at 17:28
Spen,
Thanks alot! I will give it a try.
Halherta
