Mechanical Gerber files
Graham1904
I need to mount a Nucleo-64 development PCB as a plug-in to a PCB motherboard and need to locate the mechanical Gerber files so that I can create a footprint in Eagle CAD.
David SIORPAES
David SIORPAES
Graham1904
Thank you for your reply but I cannot open these Gerbers, besides which I would like a mechanical dimension drawing with PCB dimensions in mm if possible....
You can use the free tool gerbv to open the Gerber files and take all dimensions in mm/mils/imperial.
