2019-10-24 06:07 AM
Hello community,
am writing here because I need support in designing an RFID-based system.
At current stage I have settled on the ST25RU3993 IC as an RFID reader. However, I can't understand if and how an antenna should be connected to the IC.
Can anybody guide me in the right direction?
Thank you
M
2019-10-25 12:30 AM
Hi VnKisa,
Figure 2 of ST25RU3993 DS will give you a basic overview how to connect an antenna. For more information I recommend to inspect the Resources section of ST25RU3993 and the evaluation board ST25RU3993-EVAL which comes with full documenation (Schematic, Gerber, Altium, etc.) in the its Resources section.
Regards, Ulysses
2019-10-25 12:30 AM
Hi VnKisa,
Regards, Ulysses
2019-10-26 03:24 AM
Thank you for your reply, Ulysses.
This is great advice for me (as you might have understood I'm pretty much of a beginner in RFID technology).
I will go through the Resources section in the ST25RU3993 DS and look at the eval kit.
Best,
Michele
