ST25R3911B / NFC reader / No-response timer register
VMana.1
I would like to increase no-response time by a few ms instead of 64/fc (4.72us) or 4096/fc(302.08us?), say 100ms(milliseconds). What should be the values in 0Fh, 10h and 11h registers.? I see bit4 in 0Fh register mentions time configuration in milliseconds configuration but don't how to use.
Host uses rfal API.
Thank you for your support!
Thanks,
Veera
Brian TIDAL
the rfalTransceiveBlockingTxRx() and rfalTransceiveBlockingTx() APIs in the RFAL have a fwt parameter (Frame Waiting Time in 1/fc). This will set the No-response timer registers accordingly.
Can you elaborate about your use case (e.g. which technology A/B/F/V/P2P) and explain why you need to increase the non response timer?
Rgds
BT
Brian TIDAL
Rgds
BT
VMana.1
Sorry I missed your response somehow I did not receive a notification though.
We've an application level security added and ran into some issues at the RF transport. To debug, I want to try to extend the non-response timer to a few milli seconds. We sorted out the issue. Thank you for your support.
Thanks,
Veera
