ST25R200 read/write examples
Atomic1
I am using the ST-25R200 ready-to-use NFC evaluation board for my application. I have already used the ST25R200 EVAL GUI software which functions without any problem.
Since I want to develop my own software and integrate it for the application which requires to read/write to the NFC tags, I went through the forum and found out some much helpful ST25NFC_Embedded_Lib_ST25R200_1.8.0. After installing, I went through the example ndef_read.c and ndef_write.c codes (which are very thorough in and of themselves).
I am trying to use these codes along with the required drivers and header files using VS code. I have properly included the paths for all the required headers. However, while compiling I am getting the error: reent.h source file (dependency of rfal_nfc.h) could not be opened. I am also unable to find the said header file in the installed embedded library folder.
Request for any help, since I am a novice in programming microcontrollers
Maxime_MARCHETTO
Community manager
Community manager
Hello @Atomic1,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Best regards,
Maxime
Ulysses HERNIOSUS
reent.h is not directly included by RFAL code. It sounds more like a clib issue. Maybe this one helps:
stm32cubemx-version-6-4-0-generates-code-with-missing-reent-h
BR, Ulysses
