ST25 Android app SendInterrupt bug
Martin Davey
Posted on February 27, 2016 at 02:42
I have downloaded the source code for the ST25 demo Android app (1.0.2), and have found a bug with the SendInterrupt command inType4Tagm24sr7816STCommands.java:
// SendInterrupt command
// On receiving the SendInterrupt command the M24SR generates a negative pulse on the GPO pins
// /!\ System file shall be selected by issuing the System Select command before
static final byte[] m24sr7816STSendInterrupt =
new
byte[]{
(byte) 0xA2,(byte) 0xD6,
// CAS , INS
(byte) 0x00,(byte) 0x01,
// P1 , P2
(byte) 0x00
However, P2 should be 0x1E as per M24SRxx datasheets. Thanks, Martin. #android-app
JP Miller
Posted on March 02, 2016 at 12:05
Hello Martin,
Indeed the offset should be 0x001E (ie P2 = 0x1E) as per datasheet. We'll be releasing the updated ST25 demo Android application shortly and will let you know when available.
Thanks a lot for bringing this issue out.
Best Regards,
Have a good day
JP Miller
Hello Martin,
Best Regards,
Have a good day
Martin Davey
Posted on March 03, 2016 at 13:56
Ok great - thanks for the reply.
Martin.
