Don S
Visitor II
November 15, 2017
Open the RF security session on Android device
  • November 15, 2017
  • 1 reply
  • 772 views
Posted on November 15, 2017 at 17:34
we are trying to using the ST25DV64K to implement the reading and writing data via RF between the ST25DV64K and Android device.
The area 3 is protected by RF password 3 with default password .
Tried to use the below code to open the RF security session but always return �(byte)0x01�. Could you advise ?
It would be appreciated if the sample code of reading and writing the data on the protected Area is also provided.
Thanks.
public static byte
SendPresentPasswordCommand
(Tag myTag
, byte
PasswordNumber
, byte
[] PasswordData
DataDevice ma)
byte
[] response =
new byte
byte
0xFF
    byte
[] PresentPasswordFrame
PresentPasswordFrame =
new byte
byte
0x02
byte
0xB3
byte
0x02
PasswordNumber
PasswordData[
0
PasswordData[
1
PasswordData[
2
PasswordData[
3
new byte
byte
0x02
byte
0xB3
byte
0x02
byte
0x03
byte
0x00
byte
0x00
byte
0x00
byte
0x00
    int
errorOccured =
1
    while
(errorOccured !=
0
try
            NfcV nfcvTag = NfcV.
get
(myTag)
nfcvTag.close()
nfcvTag.connect()
response = nfcvTag.transceive(PresentPasswordFrame)
            if
(response[
0
byte
0x00
|| response[
0
byte
0x01
//response 01 = error sent back by tag (new Android 4.2.2) or BC
                errorOccured =
0
//Used for DEBUG :
catch
(Exception e)
            errorOccured++
//Used for DEBUG :
if
(errorOccured ==
2
//Used for DEBUG :
                //Used for DEBUG :
return
response
return
response
#st25dv64k #android
Best answer by Olivier L
Posted on November 21, 2017 at 14:23
Hi Don,
On ST25DV64K the Area password is 64 bits long. Here is the command that you can use:
02 b3 02 03 00 00 00 00 00 00 00 00
Best regards
Olivier
1 reply
Olivier L
Olivier LBest answer
Hi Don,
Best regards
Olivier
