NFC MATRIX-M24SR and SMD antenna
evelair
Dear Community,
i'm looking for a solution for NFC antenna of range ~10mm and M24SRxx-Y. The space on double layer PCB (1.6mm) is limited to max. +/- 20mm x 8mm, tag should be read by a mobile app.
Does anyone experienced / has a reference design for such requirements ?
I have found a MATRIX-M24SR - Matrix of multiple antenna for M24SR - Documentation purpose only - STMicroelectronics - there is a SMD coil antenna which can fit, but I'm afraid that it will not couple well with mobile antenna, which probably is much bigger.
Does anoyone tested this antenna design on bench, what is a reading distance and performance ?
Thanks for help and regards !
0 REPLIES 0
