I'd like to porting example from STM32CubeExpansion_NFC6_V1.1.0 board STM32L476RG to board STM32WB55
POlcz
I would appreciate any suggestions in that issue.
Thank you in advance.
Best regards.
Piotr Olczyk
Brian TIDAL
Hi Piotr,
I've sent you the firmware package.
Rgds
BT
4 REPLIES 4
Brian TIDAL
Hi Piotr,
just to better understand your need, do you plan to use the STM32WB55 with an RTOS such as Zephyr or in bare metal mode?
Can you elaborate about your use case (e.g. concurrent use of NFC and BLE)?
Rgds
BT
POlcz
Hi Brian,
I have x-Nucleo-NFC06A1 expansion board and STM32WB55 board.
In first approach, I would like to run the sample software included in STM32CubeExpansion_NFC6_V1.1.0 on a STM32WB55 board without BLE function.
Ultimately, I would like to build a mobile NFC reader which use BLE for data transmission between host (komputer) and NFC reader.
Best regards.
Piotr Olczyk
Brian TIDAL
Hi Piotr,
Rgds
BT
POlcz
Hi Brian,
Thank You! for your quick answer. I am under impression your professionalism.
Best regard,
Piotr Olczyk
