2022-03-25 12:15 AM
CR95HF-VMD5T I'm using this part number for our design can you please help out to design antenna tuning circuit for flexible antenna
flexible antenna electrical parameters which has going to use
Inductance-1.40 uH
Frequency-13.56 MHz
2022-03-25 1:14 AM
Hi
Application Note AN5248 (ST25R95 transceiver antenna tuning circuit with EMI filter) provides information about the design of the matching circuit for ST25R95/CR95HF devices
The ST25R95/CR95HF EMI filter calculation tool STSW-ST25R003 helps to calculate and adjust the antenna tuning circuit.
Rgds
BT
2022-03-25 1:14 AM
Hi
Rgds
BT
