Hello Everybody, I need your help. Is it possible to put the result (answer) continuous to a serial terminal program?
AFido.1
I use the DEMO-CR95HF-A of the M24LR-Discovery tool Kit for reading a NFC Tag.
I would like to read the tag permanent and screen the answer to a serial terminal or record it to a (.txt) Data. The Script tool works fine, but I need the reached answer to screen or export it to a serial port. I know I can save the log, but then it is cumbersome to just filter the received answer and format it the way I need it. Screenshot 1 shows the recieved data unformated. Screenshot 2 is the formated received answer I need.
Do you have a smart solution to solve my problem?
Many thanks in advance.
0 REPLIES 0
