CR95HF USB Demo Board interface with Friendly ARM Android board
sushil
Posted on December 14, 2013 at 12:13
I have M24LR Discovery Kit.The present NFC & Data-logger android application works with NFC enable phones application. We are trying to write our own android application for CR95HF demo board for Friendly ARM board.
The Friendly ARM have Three USB host. When I connect the CR95HF Demo board to USB Host, The system detects the CR95HF Board ( Friendly ARM USB controller shows STM32xxxxx).
I already develop android layout only in friendly ARM to display temperature and Messages which is in the M24LR memory. I want to know how i can procedd further to develop the working application.
Is CR95HF dll file helps .
We check the available codes for PC Software, NFC & Datalogger application.
#software #raspberry-pi #cr95hf
Anais GALLIGANI
Senior II
Posted on January 13, 2014 at 14:36
We do provide some example of source code in order to develop your software, was it what you were looking for ?
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00275180.pdf
That you can find for example on the following page :
http://www.st.com/web/catalog/mmc/FM76/CL1766/SC1412/SS851/PF251522?s_searchtype=partnumber
Thanks ,
Have a nice day,
ST Dynamic NFC/RFID tag support
7 REPLIES 7
Anais GALLIGANI
Senior II
Posted on December 17, 2013 at 09:52
Hello
Yes the dll file mighthelp you,
Might you please give us your email adress, either on the forum either per the online support,
/st-extranet-web-active/active/en/support/online_tech_support.html
sushil
Posted on December 17, 2013 at 13:48
My Email ID is sushil.verma@knoxiatechnologies.com
ruixiang
Posted on January 09, 2014 at 06:57
Please send me also. my email: ruixiang.xu@wtmec.com
Thank you.
mathew
Posted on January 09, 2014 at 17:23
we want to try to use demo board with Java and Raspberry Pi, and Arduino, do you think it would be possible?
Anais GALLIGANI
Senior II
Posted on January 10, 2014 at 17:55
Hello Mathew,
Some Customer have been doing it.
So yes, I guess it is possible.
Have a nice day,
Kind regards,
ST NFC/RFID Dynamic tag support
mathew
Posted on January 10, 2014 at 19:55
Hi, I see in downloads just DLLs, do you have some C source or some specifications?
thanks
Anais GALLIGANI
Senior II
Thanks ,
Have a nice day,
