on 2023-05-11 1:05 AM
This depends on the coil design. Common designs are using 3mm to 5mm of gap. However, we have designed coils for 100W application with 2cm coil distance and with very good efficiency. In general, larger distance results in poor coupling and lower efficiency. Special attention to the coil design and frequency of operation can improve the efficiency.
That's interesting! It seems like optimizing coil design and frequency is crucial for efficiency in higher power applications like yours. Have you found that tweaking the coil distance significantly impacts performance, or is frequency more of a critical factor in your designs?
