we have 2 STM labels for STN3P6F6, which PBT difference, 260 C and 210 C, would you help to check what is difference or STM has PCN to changed this information, thanks,
SChan.14
Peter BENSCH
The technical parameters of the components are absolutely and completely identical, only the peak body temperature has been increased from 210DEGC to 260DEGC in the devices with the designation STN3P6F6$F1.
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
Hi Peter,
Thanks for your explanation. However, we still have some confused. Would you check again is it possible the PBT was typo error at STM mfg label?? It is because the PBT should be 260C or 220C at the JEDEC J-STD-020 accordingly.
Thanks and awaiting for your reply, thanks for your cooperation,
Best regards,
Peter BENSCH
No, it was not a typo.
/Peter
P.S. Please don't use email to answer, because it inserts your private data. Please keep in mind this is a worldwide public forum, where nobody should insert confidential data.
