2024-01-26 05:00 AM
Is there a limit of writings/erasings for the few times programmable memory of STWBC86?
How many times should I expect?
Best
2024-01-26 05:20 AM
Welcome @helderoshiro, to the community!
Yes, there is a limit, which is why it is also called "few times programmable". It is not mentioned in the data sheet, but you should not perform more than 100 erase/write cycles, the fewer the better.
Hope that helps?
/Peter
2024-01-26 05:20 AM
Hope that helps?
/Peter
2024-01-26 06:41 AM
Thank you, Peter
That helps a lot.
I was afraid that if writing on it 3 or 4 times would block programming the evaluation board, then needing to buy a new one. But I will stay far from 100.
Best
2024-01-30 11:42 PM
We have update command line for download WLC chip fw, please check this link, thanks.
https://github.com/STwirelesscharger/STSW-WPSTUDIO
