STSPIN32G0B1 Power consume
Sudhakar.R
I have working on STSPIN32G0B1 board for BLDC E-Bike. I have need 5V Supply for Motor Hall signal, Throttle and Pedal Asist sensor (approximately 60 to 70mA). Can I able to convert 12V from REG12V to 5V using 78l05. REG12V can able used to provide external supply.
ahsrabrifat
Senior II
If you want better efficiency and less heat, consider using a buck converter module (switching regulator) like:
MP1584 mini buck module.
LM2596 module.
These are cheap, compact, and efficient — much better than a 78L05 in terms of thermal performance.
