st7mc-kit and CAN??
sudome
Posted on August 21, 2006 at 06:42
st7mc-kit and CAN??
sudome
Posted on May 17, 2011 at 10:13
What would be a good solution for CAN communication with the ST7MC evaluation-kit? would it be possible in your oppinion? I want to use 5 different sensor-readings (available on a CAN-bus) to set a speed demand to a bldc motor...
Have access to a stmc evaluation-kit and would like to see if CAN communication is a viable option... for me. How to proceeed?
Any suggestions on doing it without implementing the CAN-bus in the microcontroller? Perhaps using a rs232 to CAN converter... I am primary interested in evaluating ''sensor reading to rpm'', not the CAN-implementation... suggestions?
Thanks!
/PerS
