softec STVD7 IDE
Options
‎2008-01-07 5:54 AM
Options
‎2011-05-17 1:14 AM
Posted on May 17, 2011 at 10:14
Dear ST user,
as I can see from your previous message, you are using an old version of STVD7 Indart-STX tool. I advise you to firstly update your IDE and then consult some project examples (for ST7MC MCU) at the following URL:http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&fam=15&doc=40
. This software is a Motor Control Library for BLDC motor built with version 3.1x of STVD7 from Indart. You could use it for setting up your environment and then write your own code. With my best regards, TanioOptions
‎2011-05-17 1:14 AM
who can tell me if other .c file isn't suppoted except main.c and vector.c in softec STVD7 IDE? :(
