ldong.1
Reqeust for L9369 CRC calculation documentation.
  • July 29, 2022
  • 9 replies
  • 1863 views
Hi. i'm working with L9369 H-bridge driver and i want to know how to calculate CRC code in C programming
Do you have any documentation regarding CRC implementation in C code?
thank you.
Tesla DeLorean
Guru
July 29, 2022
Would need an actual Data Sheet, not the Data Brief to determine this
ldong.1
ldong.1Author
thanks for your replying.
i have L9369 Datasheet and it says it use X^5+X^2+1 as polynomial. and it use "11111(0x1F)" as initial value.
i don't know how to implement CRC Table and get CRC value by C programing. please help me.
thank you.
Tesla DeLorean
Guru
July 29, 2022
A table may or may not be appropriate, depends on how the data needs to be processed.
Could you just use a simple bit-wise application of the polynomial?
0x25 (0x05)
ie something like, assuming a right shift, MSB fed
if (crc & 0x10)
crc = (crc << 1) ^ 0x25; // this has the secondary effect of clearing the high order bit
else
crc <<=1;
Do you have some example words / test patterns?
Send me the full data sheet or attach.
sourcer32@gmail.com
