L6480 bootstrap charge pump stop after write of configuration register
Posted on January 23, 2017 at 11:35
The L6480 controller charge pump frequency stops after a write to the configuration register. A pulse on the reset pin seems to do nothing at all. Is there a proper sequence to restart the charge pump frequency? How can I fix this?
Controller setup:
16Mhz internal clock with no output, OSCOUT, OSCIN disabled
PWM frequency devision factor = 2
PWM frequency multiplication factor = 1
Config register value: 0x2F80
