Is there more details about register settings value of PD controller STUSB4710A ?
FAlam
Hi, Currently I am using Autonomous USB PD controller STUSB4710A. I saw the data sheet but can't set resister value by reading that data sheet.where I find the complete details to know resister value.
Gregory Go.
Senior II
The easy way to configure the STUSB4710 is to use the GUI, by connecting the I2C interface of STUSB4710 to the STM32 Nucleo board (NUCLEO-F072RB).
Thus you'll be able to configure the Pull-up resistor values, or other parameters.
STSW-STUSB001 software GUI available here:
https://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-stusb001.html
If you need more details than what the ST tools available online can offer, you need to contact the technical support.
Gregory Go.
Senior II
The NVM configuration is done with the GUI.
