2020-09-27 3:02 AM
Hello =)
Do you recognise this component?
It's being used in this case between the +ve output of a bridge rectifier and ground
I've searched ST & elsewhere and would appreciate your help to identify this & suggest alternatives to replace it.
Many thanks, Craig
2020-09-27 9:35 AM
ST FUU DIODE
SMCJ40A-TR FUU
https://www.st.com/resource/en/datasheet/smcj12a.pdf
2020-09-27 9:35 AM
ST FUU DIODE
SMCJ40A-TR FUU
2020-09-28 7:02 AM
Awesome, thank you! 🙏🏻
