Gerbers and CAD files are available for EVAL-L9963E-MCU?
TLee.16
Hi ST,
I could find pdf format of those files under CAD Resources but can't find gerbers and schematic project files.
If they are available, how can I get those files?
Thank you.
5 REPLIES 5
Peter BENSCH
The PDF with layout and schematic are primarily for information purposes, because the EVAL-L9963E-MCU is not a reference design, but only for evaluating the platform. For this reason, the data is not available as a GERBER or project file.
Does it answer your question?
/Peter
Hi Peter,
Thanks for your response. But as you can see, some of "evaluation boards" has gerbers listed in their product pages;
https://www.st.com/en/evaluation-tools/automotive-ic-eval-boards.html#cad-resources
I understand your answer would be the best you can give at this moment, but your answer would not be enough for me to understand the reason why they are unavailable.
I believe ST is one of the most customer friendly companies in the world, so could you please check again if those files are available or not. That would help me definitely.
According to my information, the GERBER and project files are not available for tools for the L9963x, as you can also find on the URL you mentioned.
However, you can open a personal ticket on OLS and explicitly ask for it there, specifying your project data.
Good luck!
/Peter
Hi Peter,
Thanks so much for your kind response, and have a good day!
You're welcome!
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
