eval-l9963e-mcu GUI
alfonso_mauro
Hi, after i have downloaded the softare. I tried to monitoring a battery pack made up with 4 cells in series. When i open the GUI, only the first 3 cells are monitored the last one isn't monitored. Anyone have a solution or a schematic about the pin? Cause the gui guide says that the minimum configuration is cell 1,2,13 and 14.
Thank you so much
0 REPLIES 0
