eval L9963E board
prabhubsk
Dear All,
  I purchased the L9963e board for demonstration of the BMS systems. I installed the NI tools and opened the same and its opening.
I am unable to make a communication. I installed the FTDI driver as mentioned in the user manual in windows 10/11
When I checked in the device manager, the com port is not showing and it's not opening.  Kindly I required an support to have the communication with the PC so that I will open the SW and work on the BMS
S.Prabhu
0 REPLIES 0
