Can I replace 5 ohm NTC from circuit of application note AN2097 ?
AAror
I am trying to replicate the circuit given in application note AN2097 which is a 10W SMPS at 12V.
I am stuck 5 ohm NTC used in the circuit. Can you tell me the wattage of it. It is very expensive also, please tell me any way to replace it. Please find the document attached for your reference.
0 REPLIES 0
