2020-01-31 6:51 AM
No matter what we try, nothing happens. For case 2, the L9945 receives the PWM.
Thank you in advance. Best regads: Balázs Bámer
2020-02-04 11:40 PM
We have found the problem. The default overcurrent detection voltage was the lowest possible, to ensure the power-on behavior won't do any harm to the circuit. The L9945 kept on shutting down any FET starting to conduct immediately. By setting the OC detect voltage to a correct value the FETs could remain switched on.
2020-02-04 11:40 PM
