BTA40 700 AC 9228
ELE J.1
Searching for a replacement or datasheet for a TRIAC : p/n : BTA40 700 AC 9228it is the marking on the TRIAC i need to replace.Thank you !
4 REPLIES 4
https://www.st.com/resource/en/datasheet/btb41.pdf
ELE J.1
Yes , i've already found this , but i would like to know the value of "AC" (Sensitive and type ) , so i could find a replacement ;
(Mine is a RD91 package) ; i know that common IGt value is 50mA , but thre is also values like 100mA , etc .
Thank you for your help !
ELE J.1
i'm wondering if i'm reading it wrong : the full marking is : BTA40.700AC9228 ;
Should i read it like : BTA40 700A ? so what is the meaning of C9228 ?
Probably date/production codes
People tend to provide pictures of marking, and use-case context.
How old is the board you pulled this from?
