BLDC CONTROL METHOD
Options
‎2005-10-18 4:43 AM
Options
‎2011-05-17 1:19 AM
Posted on May 17, 2011 at 10:19I'm a student and i'm working on BLDC motors, could you explain me advantage and disavantage of controlling BLDC motor by appling PWM signal on high side of MOSFET transitsors or by appling PWM signal on low side of MOSFET transisors or by appling PWM signal on both side of MOSFET transistors Thanks for your help Best regards Eric DUPONT
Options
‎2011-05-17 1:19 AM
the explanation at your question is not so straightforward! There is a lot of concepts related to apply PWM either on high or and low side. Fortunately for you, there is also a lot of documentation that explains everything. So, I advice you to address the following URL:http://mcu.st.com/mcu/modules.php?name=mcu&file=devicedocs&DEV=ST7MC2N6&FAM=15
and donwload the following ANs: AN1946, AN2030, AN2009, AN1905. After your reading, all should be more clear. If not, please, contact again the forum for further explanations. Best regards, Tanio
