Write data to internal data eeprom of stm32L152 will crash
kevinliao
Posted on September 06, 2015 at 05:52
Hi, ST sirs,
I am using the internal data eeprom of stm32L152.
I have the problem that write data eeprom will ''crash'',
I found that when the value of data = 0x00, the system will crash.
Write other value is OK.
Is that need spacial process when data value = 0x00.
By the way, why the data eeprom need erase process?
When will the data eeprom need be erase?
I only do the read and write procedure.
Thank you.
#crash #stm32l #data-eeprom
Posted on September 06, 2015 at 14:15
I can't say I've heard of this issue before, so I'm a bit skeptical.
How does it crash? Are you sure you're erasing the right memory area?
Can you write a small/complete example that demonstrates this failure clearly?
kevinliao
Posted on September 06, 2015 at 15:19
kevinliao
Posted on September 18, 2015 at 08:22
