Windows MCU Finder app broken for STM32H5 & U5
etheory
Senior II
Split from STM32H503 incorrectly marked as having CORDIC/FMAC - this is a different topic.
Thank you, I will try this.
But in the meantime, the Windows standalone MCU Finder app has just become broken.
Selecting any entry of the PRODUCT INFO -> Segment options, return no results. i.e. if I reset, then choose STM32H5 series, or STM32U5 series, no results are shown. This definitely used to work. The Android app still works, but still shows the incorrect H503 entries.
etheory
Senior II
Unbelievably, over 7 months later, the MCU Finder app in windows is STILL completely broken when searching for the U5 range:
This is a different problem. Please make a new topic.
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
