2026-02-12 6:21 AM - last edited on 2026-02-12 7:52 AM by mƎALLEm
Edited you post for the Book title in French.
We are pleased to inform you of the publication of a new technical book dedicated to STM32 microcontrollers. Written by three professors at INSA Toulouse (engineering school, France), this book is available in French and English:
Designed with an educational approach built on 20 years of experience in the field of embedded systems, this book combines essential theoretical foundations with structured and rigorous practical application.
It uses a common thread example to illustrate the use of the main microcontroller peripherals throughout the chapters. Each chapter begins with a detailed explanation of how the peripheral works in order to provide the most generic overview possible of microcontroller programming.
This book is intended for both embedded systems developers and trainers in this field.
2026-02-12 7:32 AM
Thank you for the sharing. I close this thread to give more visibility for other users to find the books.
Meanwhile, you said one in English and another with French. But what I can see here is both are in English ;)
2026-02-12 7:32 AM
2026-02-12 7:36 AM
Yes, you're right.
How can I edit my original message?
2026-02-12 7:44 AM
@Vincent_MAHOUT wrote:
Yes, you're right.
