How to drive 24bits ST7282 LCD Display?
I want to initialize and drive 24 bits LCD display with the driver ST7282. I did not find any driver file online. Can someone please suggest me the similar driver that I can use to drive the display????
mƎALLEm
May be better to refer to the AN4861 "Introduction to LCD-TFT display controller (LTDC) on STM32 MCUs" so you can develop your driver yourself.
mƎALLEm
Andrew Neil
Seems it was already obsolete back in 2003 - that's over 20 years ago now!
So probably best to find something more up-to-date - or, as @mƎALLEm said, use the facilities available STM32s.
That post was talking about ST7282 a very old 8-bit MCU from ST. Datasheet here.
While there is a LCD driver with the same part number ST7282 from other manufacturer: https://www.phoenixdisplay.com/wp-content/uploads/2019/04/ST7282_SPEC_V1.3_201510.pdf
