Winbond Support on Elite/ConsumerII
garylai
Posted on October 20, 2004 at 01:27
garylai
Posted on September 07, 2003 at 00:44
Is it any BIOS Support on Winbond Super I/O on Elite/ConsumerII? I knew that most of the companies have changed to this super i/o instead of the SMSC one. Is it any testing BIOS for evaluation on Winbond? Thanks.
stephen239955_st
Posted on September 18, 2003 at 13:58
Unfortunatly, BIOSs are system specific. Which means that if oyu change the SuperIO, then you will need a new BIOS. This can be obtained from any of the BIOS vendors.
Our evaluation BIOS is designed for the evaluation board and therefore supports the SMSC SuperIO.
One thing you could do is to contact General Software, they may be able to help you.
cdvehicle
Bad news! SMSC can not supply industry grade chips
