WARNING L2066: Variable _startupData not found, linker prepares no startu
raunaque
Posted on December 25, 2004 at 07:57
raunaque
Posted on December 03, 2004 at 02:47
hi all
i am compiling a piece of code . The *.o file are made successfully but after that i get warning WARNING L2066: Variable ''_startupData'' not found, linker prepares no startup .Can anybody help me why this error is coming . i am using Hiware Compiler
thanks in advance
Ronnie
zomorh2
Hi
I think this warnning may be removed by adding start07.o to your
.prm file
I think you'll find 3 versions of it in your compiler/linker directories.
I think that you don't have to add this file always and you may ignore this problem
Salam
Hossam
