Ulta 09 LTCSR TBF being cleared
brian4
Posted on September 24, 2008 at 10:20
brian4
Posted on June 13, 2008 at 08:58
Hi I am using and ST7 Flite Ultra 09
I am using ''bset LTCSR,#WDGD'' to reset the Watchdog in my main loop
This seems to be clearing the Interupt flag, does a ''bset'' command have the same affect as a read.
If so whats the solution to resetting the watchdog?
Re B
[ This message was edited by: BrianM on 13-06-2008 12:34 ]
brian4
Posted on September 23, 2008 at 10:32
Bump
Anybody help with this please....
Re Brian
fggnrc
Brian,
BSET LTCSR,#WDGD is equal to the following instructions:
LD A,LTCSR
OR A,#$01
LD LTCSR,A
For this reason, the first instruction clears the Timebase Interrupt Flag.
The only way to delay the watchdog action without losing the Timebase Interrupt is:
LD A,#%10010011 ;enables Input Capture and Timebase Interrupts too
LD LTCSR,A
According to the datasheet, the Input Capture and Timebase flags should remain unchanged.
EtaPhi
