STR912FW44 and DspLib
erik2
Posted on May 30, 2007 at 17:25
6 REPLIES 6
erik2
Posted on May 17, 2011 at 09:43
I’m testing the STR912FW44 chip with GCC and STR9 DspLib. Has someone manage to compile it with GNUARM GCC?
sjo
The dsp lib has been ported to gcc in the IDEaliST from Anglia:
www.st-angliamicro.com/software.asp
sjo
erik2
I looked at the page and I can't find it. Could you please be a bit more specific?
regards, Erik
mehdi239955
Download Anglia STRx Toolchain (4.1.1) and install it, then you'll find all the Dsplib in the install folder.
MBS
erik2
Thanks!
The port seems to be exactly ly the one I did. And it has the same problem.
long in[1024];
long out[1024];
memset(&in, 0, sizeof(in));
memset(&out, 0, sizeof(out));
/*Generate sin wawe, Fs=800, f=80, amp=32767*/
gSin(in, 1024, 800, 80, 0, 32767);
test_fft = str91x_DSP_INIT();
test_fft->calc_cr4fft_1k(out, in, 1024);
When testing this, with a simple sin-wave, I don't get the expected result. I just get a lot of random data. Please help me!
[ This message was edited by: erila107 on 30-05-2007 10:35 ]
erik2
Skip my last post. I've found the same bug in my code as in the port I downloaded.
Change .word to .short in the Table_FFT.
