STR912 UART Interrupt
rmccoy
Posted on October 31, 2006 at 11:32
Posted on May 17, 2011 at 09:33
have a lock to this thread. The code is for IAR
but use the STR91xlib.
http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=4376&forum=21
rmccoy
Gentlemen(Ladies):
I am having quite a bit of trouble getting the UART0 Receive interrupt to work. I am using the Keil/ARM Realview compiler.
Does anyone have an example of working code that works the UART0 Receive interrupt?
Thanks in Advance,
-=Rich=-
amira1
Hi RichMcCoy,
please find attached an UART project using interrupt under IAR Compiler.
I hope that it will be usefull for you.
Best regards
mirou
